LS VTEC TURBO
Old Dec 19, 2008 | 05:40 PM
boosted112's Avatar
Default LS VTEC TURBO
HEY GUYS
I am having problems with my ls vtec turbo setup! If the engine has a new water pump, new radiator new fan, new head gasket and it has been cleaned and shaved, and a new thermostat, what could cause it to overheat. I am testing to make sure for any pockets of air in the system but other than that I have no idea what is going on! can you help?
Old Dec 19, 2008 | 07:56 PM
asltrucker's Avatar
Default RE: LS VTEC TURBO
see any air bubbles coming out of radiator filler hole? Head gasket match? Ignition timing within specs? What u look for if your motor overheat? Gauge or steam?
Old Dec 20, 2008 | 06:24 AM
boosted112's Avatar
Bubbles no head gasket matches the gsr head tha I am using. Timing I havenot checked but pretty sure within tolerance and I use water temperature gauge
Old Dec 25, 2008 | 04:19 PM
boosted112's Avatar
Hey Everyone:
Thanks for all the input regarding the overheating process. We found found the problem. It was an underpowered cooling fan. We replaced it with OEM and car made 429whp with 336lbs of tourque at 15psi. Upgarding injectors and computer should produce 750+ on next dyno. The funnest build i have ever done so far. will keep every one updated!
Joel
boosted112
Nov 30, 2008 10:01 AM
boosted112
Nov 18, 2008 02:12 PM
evidentloss
Oct 8, 2008 05:02 AM
excellon
Feb 27, 2007 04:50 PM
cml2105
Sep 28, 2006 07:02 PM
