need advice or help??
Old Mar 29, 2012 | 02:49 AM
newbiehondaowner's Avatar
Default need advice or help??
hi i recently got a 97 ek vtec turbo, was running extremely well, very very fast!!, unfortuantly the head gasket went..so i took it in to get fixed, it had a 2.6mm head gasket.. for some reason the "professionals" *coughcough* reckond that replacing it with a 1mm gasket was sufficient enough, and have had the same setup in a car that they built running 300kw, but for some reason after a tune my car seems unbeleivably slow now and really doesnt seem to have much get up and go at all.. would the head gasket thickness have anything to do with how fast a car goes? or is it all up to the tunning? im really frustrated because it was really fast and after spending all this money for this work and tune have ended up with a lemon and i dont know why and the mechanics seem to just keep brushing it off.. there hasnt been anything change other than the thickness of the gasket.. please help someone??
Old Mar 29, 2012 | 11:36 AM
Welcome to the forum,if it's losing compression it will lose power.
Old Mar 30, 2012 | 11:11 AM
thickness difference of the gasket of 1.6mm should not affect the power of the engine. if there is a way to check the pressure of the intake may tell you where your loss of power is, if the turbo oil is incorrect or dirty may have a loss of power. Pop off valve maybe set low. and as buckwheat states low compression can cause a loss of power. is the engine smoking more than before when engine is accelerated.
Old Apr 15, 2012 | 08:14 AM
nifer's Avatar
when i checked the compression is ok it is in the safe zone itself but still facing the problem do not know the reason y?
Old Apr 27, 2012 | 01:07 AM
Thomas Walsh's Avatar
Hello. I just recently bought a 1997 civic lx and the guy I bought it from installed a 2000 Honda civic 1.6 vtec motor in it and didn't replace the computer or harness' and simply wired the vtec solenoid to the computer so it doesn't work.mwhat do I need to do it all right?
Taylor_green
Oct 6, 2014 10:43 AM
Honda
Jun 5, 2007 06:45 AM
Mystere
May 31, 2007 10:30 AM
kenbrown86
Feb 19, 2007 07:44 PM
bkmass
Dec 5, 2006 01:44 AM
