Need help
I have a 06 accord with the 2.4l. I attempted to change the timing chain tensioner and the pin fell out as I was removing it. It is now wedged in place. I can’t compress the plunger as I can’t reach it. What can I do? I really don’t want to pull the engine down. Any help at all. I thinking of trying to use a cut off wheel to cut it down to size. Obviously I would pack the engine with rags do no metal bits get in. Thoughts? I’m freaking out here. Thanks
The pin would be in the new tensioner so I assume you mean the pin was pulled before you were ready. If so, remove the tensioner and use a vise to compress it and install the pin.
unfortunately it’s the old one that is stuck. The new one is still sitting in the box
00Vette
Apr 1, 2015 10:01 PM
