Need help
Old Oct 31, 2022 | 04:38 PM
wrenchspinner's Avatar
Default Need help
I have a 06 accord with the 2.4l. I attempted to change the timing chain tensioner and the pin fell out as I was removing it. It is now wedged in place. I can’t compress the plunger as I can’t reach it. What can I do? I really don’t want to pull the engine down. Any help at all. I thinking of trying to use a cut off wheel to cut it down to size. Obviously I would pack the engine with rags do no metal bits get in. Thoughts? I’m freaking out here. Thanks
Old Oct 31, 2022 | 05:03 PM
One post is enough.
The pin would be in the new tensioner so I assume you mean the pin was pulled before you were ready. If so, remove the tensioner and use a vise to compress it and install the pin.
Old Oct 31, 2022 | 06:17 PM
One post is enough.
unfortunately it’s the old one that is stuck. The new one is still sitting in the box
Old Oct 31, 2022 | 09:52 PM
What pin are you talking about? Get a picture or two of it.
Old Oct 31, 2022 | 10:03 PM
the pin that holds the tab in keeping the tensioner compressed
Old Nov 1, 2022 | 10:00 AM
I have this for you.
  1. Align the holes on the lock (A) and the auto-tensioner (B), then insert a 1.2 mm (0.05 in.) diameter pin or lock pin (P/N 14511-PNA-003) (C) into the holes. Turn the crankshaft clockwise to secure the pin.
  1. Remove the auto-tensioner.
whatchagonnado
Sep 25, 2022 08:50 AM
TCV
Sep 5, 2019 08:13 PM
00Vette
Apr 1, 2015 10:01 PM
hitadeercivic
Dec 16, 2005 02:55 PM
