Noisy power steering pump Odyssey 2010
Hi everybody, I have a Odyssey 2010 EX-L and yesterday the power steering started to make noise. The sound is like it was running low on fluid but I checked the reservoir and is full. I turned off the engine, after a few minutes turned on the engine again and there was no noise. I Started to drive the vehicle again, and after a few minutes the noise returned. There is no fluid leaks on pump, hoses or rack and pinion. I think is the pump but I'm not sure. I appreciate any help on the topic.
Thanks to everyone
Thanks to everyone
Usually, it is an O-ring on the power steering pump that fails
There won't be any leakage of power steering fluid
But, the failed O-ring will allow air into the pump and cause noise.
Yes, it is the O-ring on the in-take side of the pump.
There is a OEM, Honda, O ring repair kit for it.
Most people just end up replacing the pump
Or it could be the other O-ring that ckev70 mentioned
Good luck
Good luck
toicy4ya
Mar 19, 2011 01:55 PM
