oxygen sensor trouble
Old Jul 11, 2006 | 03:03 AM
chuck norris hx's Avatar
Default oxygen sensor trouble
A few months ago my 98 civic hx 5spd threw the oxygen sensor code. I tried cleaning it a few times, but it always threw the code again. So I replaced the sensor (which was $400) and it threw the code again just as quickly as did the times before? The code its says is a slow response from the bank one sensor. Any idea to what would be going on would be greatly appreciated.
Old Sep 19, 2006 | 09:27 AM
proff's Avatar
Default RE: oxygen sensor trouble
what code did you see and how did you get the code to show up?
Where is a table to show what code means what ?
Old Sep 29, 2006 | 09:34 AM
proff's Avatar
is it a 4 wire o2 sensor?
Is yes
the 2 black wires are the heater wires
you should measure 50 Ohms accross them
If over 1000 ohms replace it
Old Nov 30, 2006 | 10:24 AM
Benniehonda's Avatar
make sure u use a Honda Ho2s.Possible Pcm issue
Clay
Aug 9, 2009 11:55 AM
celoftis
May 28, 2008 05:41 AM
Morky
Mar 23, 2008 07:11 AM
Bill
Mar 1, 2008 08:48 AM
1998HondaCivic
Jan 20, 2006 02:13 AM
