Question on using loctite
Old 04-03-2019, 02:50 PM
porkenstein's Avatar
Default Question on using loctite
I have taken the side drive belt cover on my Honda Elite 110 scooter, the one pictured below. Simple question as haven't done this type of work before. Do I want to use loctite on the bolts when I put the cover back on? Also if I should use loctite would the lowest strength purple be my best choice. Thanks in advance.
Old 04-04-2019, 01:14 AM
just a heads up, when using Loctite, this means you do not want the bolt/nut to ever back off. you may have difficulty taking it apart in the future.
Old 04-30-2019, 04:09 PM
dgough's Avatar
Probably not necessary but if you use some, use the blue 242.
Old 04-30-2019, 07:43 PM
Yes ,as stated above be careful there are varying degrees of strength in loctite,use the purple.
QuiGonJohn
03-22-2020 09:08 AM
tompass
02-11-2020 05:21 AM
windnsalsa
04-03-2018 02:35 PM
Snap
05-28-2009 01:02 PM
shark254
10-10-2006 10:59 PM
Quick Reply: Question on using loctite
