Upper Cover Timing Belt--Broken Bolt Housing...& Misc
Old Apr 3, 2018 | 02:35 PM
windnsalsa's Avatar
Default Upper Cover Timing Belt--Broken Bolt Housing...& Misc
Missing Parts! Important For Finishing Timing Belt Replacement Project???Mod, please move if this doesn't fall under "urgent" sub-forum. I would want to know if I need replacement parts now while I have all timing belt related parts removed and need to get the car running tomorrow.
Model: see signature
Issue #1:
The timing belt front upper cover is usually attached by 2 bolts to the rear/back upper cover [=BUC, which is between the cylinder head and the cam sprocket]. The front part [bolt area towards the radiator side] can no longer be bolted because the plastic sleeve/housing/tab of the BUC broke. The BUC houses the bolt's metal barrel that secures the bolt.
The BUC costs alot for just a stupid plastic back cover plate. Would there be any issue if that left bolt tab area is without a bolt attached in the long term? So, the front upper cover would only be secured with only one bolt [located towards the firewall side] remaining.
Issue #2:
The rubber seal around the tensioner main nut is missing. Would this be a problem?
Illustration Pictures of Parts below:
*Very annoying, new members can't include external link. Also, very frustrating experience here of attaching any image [e.g. size quota, but my attachment was clearly under maximum limits]
Illustration Pictures of Parts:
https://www.hondapartsnow.com/Page_P...-belt&Diagram=
item #3
11820-P0A-000
Cover, Timing Belt (Upper)
item #4 [BUC]
11830-PAA-800
Cover, Timing Belt Back
*the area affected is the bolt hole to the left of #16
item #22
tensioner adjusting nut rubber seal
In care of...2000 Accord EX 2.3L sedan F23a4
windnsalsa's Avatar
OT: curious if this is bad for anything if I turn on the engine, while many parts are removed [timing, balancer & accessory drive belts, pulley tensioners, balancer drive & belt pulleys,]. I might have to wait for my brother to get some parts at the dealership and get a couple things done. I might want to heat up the engine and open up the heater core to drain possibly more coolant as well as help drain the oil for an oil filter change.
Carson Logwood
Jan 16, 2017 09:02 AM
sloweddi
Feb 3, 2015 07:47 PM
Sucreem
Aug 10, 2011 01:03 PM
john917v
Oct 1, 2010 10:25 PM
ndrew2505
Nov 2, 2008 07:45 PM
