reverse lights not turning on...
RE: reverse lights not turning on...
welcome to the forum, check the bulbs to make sure they are good, also check to see if you get power to the bulbs, then check the reverse switch has power to it. If the reverse switch has power, and you shift in to reverse and there is no light, switch bad.
JennyBoo311
03-04-2021 08:06 PM
cookiekare
09-24-2019 12:27 AM
civic2017
07-02-2008 05:16 AM
