Sat Nav/ GPS Issues
I have only just acquired the car (very low mileage and mint condition) I tried as per manual but when i turn the engine off it resets. I understand there is an issues with the coding of the GPS system since Jan 2022
Did you check all the fuses?
Can be done with a test light. Clip to ground and probe to the test points on the fuse.
If both sides of the fuse lights up then fuse should be okay
If only one side then fuse can be blown
If both sides have no light then there may not be power applied to the circuit.
Maybe a wiring issue????
chewbob
Jan 19, 2022 09:41 PM
