Sat Nav/ GPS Issues
Old May 24, 2022 | 09:06 AM
BobV's Avatar
Default Sat Nav/ GPS Issues
I recently acquired a 2008 CRV and cannot set the clock. I've been advised by my local dealer Honda are having issues with the GPS system and dealers are awaiting a fix from Honda
Old May 24, 2022 | 09:39 AM
Did you tell them you have a 2008 model? Did they tell you the GPS patch would fix your clock?
Old May 24, 2022 | 03:15 PM
BobV's Avatar
Yes i was at the dealership and nothing mentioned about a patch. What exactly is that?
Old May 24, 2022 | 03:53 PM
The patch is the 'fix' for the GPS. It's software.
Old May 25, 2022 | 12:15 AM
BobV's Avatar
My local dealer knows nothing about this so anymore information would be helpful
Old May 25, 2022 | 12:48 AM
Just wondering why a 2008 in 2022 would still have a need for a patch?
14 years and it still doesn't work?
What does the owner's manual say about setting the clock??
Old May 25, 2022 | 12:53 AM
BobV's Avatar
I have only just acquired the car (very low mileage and mint condition) I tried as per manual but when i turn the engine off it resets. I understand there is an issues with the coding of the GPS system since Jan 2022
Old May 25, 2022 | 08:10 AM
Turn off and it resets sounds like there is no power for constant memory
Did you check all the fuses?
Can be done with a test light. Clip to ground and probe to the test points on the fuse.
If both sides of the fuse lights up then fuse should be okay
If only one side then fuse can be blown
If both sides have no light then there may not be power applied to the circuit.
Maybe a wiring issue????
Old May 25, 2022 | 09:10 AM
Agree with avisitor in that you are losing the memory line.
chewbob
Jan 19, 2022 09:41 PM
magikmike
Jan 29, 2019 08:58 AM
N0uri
Jul 25, 2014 06:15 PM
juanalove
Aug 12, 2013 11:22 PM
