squealing noise at low speeds? sounds like brakes but isn't!
Old Nov 3, 2010 | 12:36 PM
aeli's Avatar
Default squealing noise at low speeds? sounds like brakes but isn't!
My 2007 Honda Civic (manual) recently started making a sqealing noise, it sounds like metal on metal, when I am moving at very low speeds. It mostly happens when I am backing out of my garage while turning the wheel to the right, but it has also happened on other occasions. I am always going really slow, about 7 mph, and it happens while coasting or pressing the gas pedal. The brakes don't seem to have an effect, the car only stops making the noise if I speed up or stop completely.
Anybody know what this could be? It sounds like something is rubbing and needs to be greased, but I have no idea what.
Thanks!
Old Nov 4, 2010 | 03:26 AM
check your front brake pads. there is a piece of metal called a tattle-tail which indicates your pads are worn to limits and time to change. this will create a high pitch squeal.
Old Nov 4, 2010 | 10:26 AM
That would be my guess
Old Nov 9, 2010 | 10:59 PM
lowlife9's Avatar
hmm i would suggests you check the power steering fluid levels they mite be to low. it also could be a loose belt making a screeching noise.
Old Nov 14, 2010 | 05:59 PM
xylocor's Avatar
could be trans bearings, front hub bearing or part of you steering system like the rack-n-pinion. If driven Hard say with heavy mods might be an input or out put shaft thats stressed and about to break, but let just hope not on this last one. Good Luck & God Bless
Cramangelo
Feb 24, 2012 11:45 AM
hondaaccordsohcvtec
Mar 14, 2011 10:56 AM
sparky-r22
Oct 3, 2009 03:55 AM
derekcentrico
Aug 3, 2009 12:22 PM
