Steering wheel not returning
In question is our 03 Accord 4cy 307,000 on the odometer. My question is while turning right and left the steering wheel doesn't right its self straight again. The power steering pump needed replacing and maybe 30,000 miles later the pressure line developed a leak so I replaced all the hoses re filled the system with "Genuine" Honda PS fluid. Within a month my problem started with the steering wheel not righting its self. Now we have owned the car since new and to the best of my knowledge I'm not real sure if I used Conventional fluid or the Honda type fluid in the past. Is my Rack n Pinion the problem I have or maybe something else.
Thanks in advance for any help.
PS I know long winded but it helps to give as much info up front.
Possible causes are binding linkages, bad wheel alignment, faulty power steering rack. Rare to have a bad alignment so bad that the wheel does not want to return.
But, check for bad ball joints and bad outer steering tie rod. Good luck.
Now for the first New steering pump (MPP) bought from O'Reillys it was QUITE "noisy" like a high pitch "whining" RPM up & down pitch so it was returned for refund. I got a New one from Rock Auto (Cardone) and "amazingly" the whining went away. So like I said before I can't remember if I used a "generic" brand fluid to top off the reservoir in the past but all I do know is since replacing any of the new P/S parts I have used P/S fluid that states usage for Honda's.
PS, should also have said our Honda was made in Japan not here in USA if that matters.
Just waiting to order (not yet ordered) a new Pow. Strg. Pump and a new Rack-n-Pinon from Rock Auto then I'll see what if any thing changes. Haven't ordered anything yet as I have a question here asking if these two wordings "Hydraulic Power Steering" and "Power Steering" units are the same.
Hydraulic means fluid and your power steering does use fluids.
So Hydraulic power steering and power steering would mean the same in your case.
There are other types of power steering. Example would be electrical power steering.
Where power would come from an electrical motor to assist in turning the steering wheel
Japan made vehicles requires a matching power steering rack. USA made vehicle is different and requires one for USA made.
So the Honda when ordering parts should I be looking for parts" made for" Japan cars?
It is important to check. I know on my 2007 CRV, the power steering rack has to be made for a Japanese vehicle since my vehicle was made in Japan.
The VIN gives this information. However not all Japanese cars requires specially made for Japanese car parts. But, it is important to check.
Sometimes in the description of the part it may mention for Japanese made vehicles??
S * h * ! * T more "Disaster" for us, The front right half shaft came apart at the inner joint trans area along with the lower ball joint split in two. Had AAA tow it home and waiting for this weekend to get under it and get a better look at the damage. I'm not sure if this could have something to do with my steering problem or not. Hoping when the axle broke nothing else besides the axle and ball joint is all is needed for that part fix. My wife was turning into a Grocery store driveway maybe @ 5 mph so it just broke and stopped pretty quickly.This time I'll be replacing both sides upper & lower Ball Joints and A Arm bushings also.After this axle fix I'll drive it to see if this fixes it or more is needed.
PS, avisitor from our last conversation on USA & Japan cars for ordering parts RockAuto does for some parts call out for USA & Japan fitment but in a lot of parts nothing is mentioned, hope its not a crap shoot.
Dezso3
Oct 29, 2015 06:49 PM
