Trouble starting 2014 Honda Civic
Old Mar 25, 2022 | 08:54 AM
BradW's Avatar
Default Trouble starting 2014 Honda Civic
Over the past couple of weeks when turning my key to start my car it sometimes (not always) won't turn over but all, but all the lights are on. Total silence when, I turn off the key and try again - sometimes it works but sometimes it takes a couple of tries. The other thing is I can go several days and it works fine. Any ideas, battery maybe. I had this checked a few months back during regular maint but they can go anytime I guess.
Old Mar 25, 2022 | 04:37 PM
Sounds more like the ignition switch or relay.
Old Mar 26, 2022 | 12:12 AM
Intermittent no crank, no start can be due to corrosion on the battery posts or cable terminals.
Before spending money one a new battery, try cleaning the battery posts and cable terminals with a wire brush.
Follow negative cable to chassis ground and clean the contact points.
Check the battery for 12 volts. Load test the battery.
Can you see where the starter solenoid is? Can you reach in there with a wire?
Putting 12 volts to the solenoid terminal should crank the engine.
Other than the battery is the ignition switch on the back of the ignition lock can sometimes go bad.
Old Mar 26, 2022 | 07:25 AM
BradW's Avatar
Thanks I'll look into this and post back.
adutta3
Oct 27, 2021 08:23 AM
vmoo
Mar 28, 2020 04:16 PM
mohd3333
Dec 12, 2009 03:15 AM
honda114
Jul 4, 2009 07:30 PM
carewbeats
Jan 2, 2009 04:40 AM
