2 problems...please help
Old Mar 7, 2009 | 05:13 PM
hondachic's Avatar
Question 2 problems...please help
I have a 1990 Honda Accord Lx Coupe. I have two problems.
One the electric seat belt is stuck (in open door position). I need to get it unstuck.
Second One...I can drive it and everything is fine. I can drive it and cut it off & it not crank back until something cools off.
ANY SUGGESTIONS
Old Mar 9, 2009 | 12:10 AM
josh2113's Avatar
Member
The seat belt thing you may need to get a new one or a salvage one. Maybe just a fuse.
The starting problem maybe the temp sensor.
Old Mar 9, 2009 | 04:45 PM
welcome to the forum. the door open seat belt position may be the drive motor not working or sticking, I beleive it is located in the door center post if you go to autozone.com or to hondaautomotiveparts.com and go to the repair and door it will show you a diagram of the motor.. before you change it, check to see if youhave power to the door motor.
On the engine not starting after warm, it usually is the main relay. when warm after start and driven then shut down, will have to wait awhile 10-15 minutes before it will restart.
Old Mar 10, 2009 | 07:34 PM
hondachic's Avatar
Thank you so much....so is the relay a normal thing?
Old Mar 10, 2009 | 07:42 PM
yes the relay is a common thing, and is the seat belt, and a lot more minor items, but is a great car for mods and fun to drive. Just remember, it does not have air bags, so don't drive faster than your Guardian Angel can fly!!
Old Mar 11, 2009 | 04:11 PM
hondachic's Avatar
Well i haven't driven the car all day & I tried to crank it at 4pm & it wouldnt...(its doing like it did b4)
Old Mar 11, 2009 | 10:50 PM
is the day warm?, with the windows closed? this would cause the relay to not allow the start. I do take it that the engine turns over but not start. And the battery is at full charge or close to it.
Old Mar 12, 2009 | 04:38 PM
hondachic's Avatar
Yes its a new battery & it tries to start. The day was 78 degrees & windows were closed (i wasnt at home so i had it locked up)
do u know where there is a diagram of the relay & where its located
Old Mar 12, 2009 | 05:22 PM
go to autozone.com and register your car for free, and go to component location, after you locatedyour part and it tell you where it is, go to hondaautomotiveparts.com and locate the relay under electrical.
Patrick Rimer
May 13, 2013 08:32 AM
benitez63035
Dec 6, 2010 06:32 PM
Unccmike49
Sep 18, 2010 09:01 AM
Derrick87
Sep 18, 2010 08:16 AM
oojuanky
Mar 10, 2010 03:28 PM
