2000 Accord Clock Light
I just replaced a single cd player in my Mom's 2000 Accord. In doing so, I disconnected the clock first, then pulled the face plate off from around the Radio and CD player. When I reinstalled everything, everything works except for the clock light. The clock itself works - just not the light. Again, this is not a clock on the radio, as it is the OEM radio. It is the small clock between the vents.
Any ideas? I will probably buy a Chilton's book if I can't figure it out. I thought it might be a fuse, but if the clock itself is working, I can't see it being that. I have reverified the connectors are secure.
RE: 2000 Accord Clock Light
If you ever figured this out let me know. I had some glitchy issues with my clock just the same. Once I installed an aftermarket cd player, the clockstarted consistantlyreverting to 1:00 everytime the car is started. Its so annoying Ive just completely disconnected it.
the clock is quite easy to take off. This happened with my 2002 accord i took it to the dealership they told me 45.00 here the bulb was only 5.00 and it took me 5 minutes to do there are two prong on each side of the clock and it just snaps out and the bulb screws into the back.
