2000 Accord Clock Light
Old Dec 25, 2006 | 10:45 PM
jrecufan's Avatar
Default 2000 Accord Clock Light
I just replaced a single cd player in my Mom's 2000 Accord. In doing so, I disconnected the clock first, then pulled the face plate off from around the Radio and CD player. When I reinstalled everything, everything works except for the clock light. The clock itself works - just not the light. Again, this is not a clock on the radio, as it is the OEM radio. It is the small clock between the vents.
Any ideas? I will probably buy a Chilton's book if I can't figure it out. I thought it might be a fuse, but if the clock itself is working, I can't see it being that. I have reverified the connectors are secure.
Old Jan 6, 2007 | 04:17 PM
kornfox's Avatar
Member
Default RE: 2000 Accord Clock Light
If you ever figured this out let me know. I had some glitchy issues with my clock just the same. Once I installed an aftermarket cd player, the clockstarted consistantlyreverting to 1:00 everytime the car is started. Its so annoying Ive just completely disconnected it.
Old Feb 1, 2007 | 06:46 PM
BlkAccordCoupe's Avatar
did you check the bulb on the back of the clock?
Old Mar 21, 2007 | 05:39 PM
johnfm3's Avatar
the clock is quite easy to take off. This happened with my 2002 accord i took it to the dealership they told me 45.00 here the bulb was only 5.00 and it took me 5 minutes to do there are two prong on each side of the clock and it just snaps out and the bulb screws into the back.
Old Mar 28, 2007 | 11:26 PM
jombolo's Avatar
I'll just back what johnfm3 said. i did the same thing, just a small light that went out on mine about 2 yearsago, not hard to replace. can get the light bulb at your local autoparts store for cheap.
Sue
May 9, 2016 06:35 AM
acmech52
Dec 12, 2009 03:20 AM
Domaeromi
Dec 11, 2009 06:36 AM
tferstl
Dec 5, 2008 07:22 AM
hd3
Nov 15, 2006 12:56 AM
