2000 Accord EGR system clogging
Old Sep 29, 2006 | 04:32 PM
jim97gst's Avatar
Default 2000 Accord EGR system clogging
I have a 2000 Accord V6. The check engine light is on, and I found out it's the EGR valve. Apparently it's a known problem and there is a TSB (#011001) for the EGR system clogging. Unfortunately, I'm 3,000 miles over the 80,000 mile extended warranty for this particular problem. Honda sells a "kit" to remedy the problem for $85. One of the techs told me that the intake manifold needed to be removed and a new hole drilled in it. It's 3 hours of labor at $92/hr, so it's going to cost me at least $360 to fix this problem.
My question is, does anyone know if you really need to remove the intake manifold? Has anyone ever attempted this themselves? Is it really that big of a job? Should another mechanic be able to get a hold of the TSB information, or does only Honda have access to that?
Thanks
Jim
Old Jan 27, 2008 | 02:28 AM
dougster01's Avatar
Default RE: 2000 Accord EGR system clogging
Jim,
What was the final verdict on your EGR valve? Or was it finally determine to be some other problem?
Doug
Dagonus
Jun 2, 2014 05:22 PM
HondaJohn
May 22, 2010 02:53 PM
sucmanh
Aug 12, 2008 12:42 AM
sucmanh
Aug 12, 2008 12:39 AM
Carl95
Feb 24, 2007 09:29 PM
