2002 Accord V6 Automatic Transmission problems
Old Jun 25, 2020 | 11:12 AM
Jaymo888's Avatar
Default 2002 Accord V6 Automatic Transmission problems
My 102,000 tranny has ben shifting harder than usual. I've been advised to add a transmission oil cooler and change the tranny fluid every 15K miles. I also saw someone clean out their solenoid located underneath the air filter assembly. Is the latter advised? Will it mess up the seals?
Old Jun 25, 2020 | 08:47 PM
if you have never had the fluid changed, change it, run it for a while, then change it again. then change it once each year. do one item at a time or you will not know if the fluid change fixed the problem. also you do not need a trans cooler if you do not tow anything. trans coolers are used to assist transmissions that have heavy pull load for long distance.
Old Jun 25, 2020 | 09:30 PM
Jaymo888's Avatar
I'm really hoping it's nothing more than that. Also, would adding a trans oil cooler have negative effects? I just moved to FL and with the transmissions in CG7 being "glass like" it couldn't hurt, right? Thanks for the feedback.
Old Jun 25, 2020 | 11:09 PM
putting in a trans cooler should not hurt the transmission.
debodun
Mar 23, 2019 12:09 AM
Honda_Addiction
Sep 12, 2018 02:30 AM
baritus
Feb 26, 2010 02:27 AM
Zukisamu
Jan 2, 2009 03:37 AM
mashermancan
Aug 20, 2006 01:33 PM
