2013 2.4L Accord starting sound
Old May 8, 2021 | 12:14 PM
PapaHomer's Avatar
Default 2013 2.4L Accord starting sound
2013 Honda AccordEX CVT (auto) Sedan4 Cylinder 2.4 L (yes there was a TSB for 6 cyl)
106,4XX miles"Push button" start
Most frequently seems to start fine. Only when cold there is a noise that sounds like something rattling or loose immediately after car turns over. Here's some audio:
https://drive.google.com/file/d/114c...ew?usp=sharing
Never makes that noise after it's warm...or not nearly as noticeable.
Recently on just two occasions, the starter has continued to turn the engine ...until I release my foot from the brake. Then the engine takes over.
Starter?
Thinking about tackling myself .
Thoughts or comments appreciated.
Many thanks !
Old May 8, 2021 | 07:24 PM
when starting engine and the starter continues to turn, solenoid may be sticking. or ignition switch sticking if you have a lot of other keys attached to the honda key ring. the noise after start may be. loose exhaust shroud especially around the cat. rocker arms may need adjust. exhaust shroud cover.
Old May 8, 2021 | 07:46 PM
PapaHomer's Avatar
Thanks... I thought of catalytic converter shield. I'll have to listen again. What I could see get/to seemed OK (not loose).
Appreciate it.
Kateshonda2013
Jun 23, 2023 09:10 PM
dichdiver
Feb 16, 2018 10:13 AM
Quan20
Oct 27, 2016 07:54 AM
Hapkidokid
Aug 19, 2013 10:44 AM
Diz
Mar 15, 2013 08:41 PM
