2017 sport cvt slipping
Old Mar 10, 2019 | 06:49 PM
Buffalobill25's Avatar
Default 2017 sport cvt slipping
Cvt started slipping at 32k. It started off acting differnt , a little sluggish than normal, idling a bit rough, and at low rpms driving rough so I changed fluid twice. Now today it slipped when pulling out in traffic. What is causing this??
Old Mar 11, 2019 | 02:11 AM
welcome to the forum. you mentioned you changed the fluid twice, what type of fluid did you use. If it was not Honda only fluid, that may be the cause. it should still be under warranty, Honda should fix it but make sure you're using the correct Honda only fluid,
Old Mar 11, 2019 | 04:32 AM
I used the honda hcf-2 fluid.
Old Mar 12, 2019 | 12:52 AM
it may be the segmented spline slipping on the spools causing the trans to drive rough or slip. get it to Honda to fix, document what is happening and even at the dealership.
Old Mar 12, 2019 | 04:41 AM
I'm bringing it to honda thursday. Gunna baby it for now. See what they say.
Old Mar 12, 2019 | 04:45 AM
What exactly is that?? Is that the drive pulley shaft that connects to the torque converter?
Old Mar 12, 2019 | 08:46 AM
Ok so after driving this morning , it may not exactly slip. If I slowly accelerate the rpms will go up to about 2-3k and hang there and accelerate sluggish then jump all the way up passed 5k . Never did this before.
Old Mar 13, 2019 | 12:06 AM
to explain how a cvt works is difficult, need to see a you tube video. the segmented drive has a bunch of segments on a multi steel belt that transfers shaft power to converter drive and they ride on 2 cones. I don't make sense until you see the video. it was interesting how it works.
Lochinvar
Jan 6, 2019 04:00 PM
Neil Greely
Feb 10, 2017 06:17 PM
joeblack1980
Jan 9, 2016 08:51 PM
hokietiger
Feb 11, 2015 03:15 AM
prof.bart
Oct 28, 2012 09:07 AM
