92 Accord EX Code 12 EGR issue
Old May 19, 2010 | 09:36 PM
HondaJohn's Avatar
Default 92 Accord EX Code 12 EGR issue
Has anyone had problems clearing an EGR valve problem with an ACCORD?
I have replaced every part of my EGR valve circuit except the wiring harness! (BUT I DID inspect and verify that it had continuity)
I hooked a vacuum tester to the valve with the engine running.
I hear the idle speed drop, and engine run rough until I release the suction.
The diaphram on the valve is good. The resistance on the feedback pot is good too. ( AS compared to TWO other valves I tried from other 92 Accords)
I replaced the EGR valve anyway. (NEW GASKET) Still got a Code 12
Replaced the Computer - Still got a Code 12
Connected a vacuum gauge to the EGR valve control line and fed 12 volts to the solenoid in order to verify good vacuum and solenoid control.
Next, I even cranked up the engine WITHOUT the egr installed to verify no clogged passages. I assure you - IT IS NOT CLOGGED - Interesting sound though ...
So my question is what else can I do ?
I don't have Honda's test harness to place between the computer and the rest of the wiring harness.
Should I buy a NEW EGR valve ? I was quoted prices from $150 - $170 bucks. That $$$ buys a lot of speculation.
About the only thing I haven't verified is IF the computer signal to the EGR Solenoid is actually getting to the solenoid. I can probably rig up a test light to see when / IF the solenoid is getting a 12 volt signal while driving down the road. I'll try that in the morning.
Thank you for taking the time to read this .
Any and ALL ideas / suggestions are welcome. I have got to get this car to pass inspection.
HJ
Old May 21, 2010 | 11:05 PM
HondaJohn's Avatar
Default Code 12 EGR valve update
Happy to say that I tracked down my problem.
EGR valve Solenoid was the culprit.
Even though it tested well at idle, it apparently did not have the response time the replacement solenoid did. I even went so far as to put a TEE into the vacuum line and taped a vacuum gauge to the windshield so I could verify the EGR vacuum port was functioning while driving down the road at 40-50 MPH. I was DESPERATE ! (Looked funny too)...
MORAL of the story:
Change the EGR solenoid if you know the EGR valve is good.
HJ
Old May 22, 2010 | 03:35 AM
That is a good post, thank you the info and how you fixed it. Welcome to the forum
Old May 22, 2010 | 02:53 PM
HondaJohn's Avatar
Default I'm NOT out of the woods yet !
Just got back from the Inspection station.
You guessed it - I failed.
Seems that the car has NO catalytic converter !
I bought this car in a rural Texas county that does NOT test for tailpipe emissions. Got a good deal though ... OUCH now I have to get a catalytic converter & install it.
Moral of the story - Add catalytic Converter to my used car checklist.
Later today or next week I will post a copy of my check sheet I built for examining a used car. Actually it was originally my uncle's list, but I re-wrote it for newer vehicles. (Gotta give credit where credit is due)
Wish me luck on my next trip to the inspection station.
HJ
PaulPool89
Aug 19, 2014 06:40 PM
Dagonus
Jun 2, 2014 05:22 PM
usahoe18
Feb 27, 2014 08:23 AM
jim97gst
Jan 27, 2008 02:28 AM
Carl95
Feb 24, 2007 09:29 PM
