93 Accord Over heating
Old Feb 7, 2010 | 12:29 PM
nithinbuttime82's Avatar
Default 93 Accord Over heating
the water pump isnt making any noise at all and i just put a new thermostat in and its still over heating. any ideas?
Old Feb 8, 2010 | 06:37 AM
matimar30's Avatar
Member
hmm...
my 93 lx is rock solid when it comes to cooling. i had a leaky cap that i didn't know about and it still ran cool. you do know that you replace your water pump every time you do your timing belt.. right... other than that the radiator was replaced on mine once in it's entire life because i got a hole from a stupid rock in the freeway.. other than that it's rock solid.. oh.. you do know that you need to flush and refill your coolant every 3 to 5 years depending on the type of coolant you're running.. right..
Old Feb 8, 2010 | 09:58 AM
The new thermostast may be bad or installed upside down,the cap may not hold pressure,check those first,if still not cooling the radiator may need cleanning by a professional.
Old Feb 8, 2010 | 10:45 AM
do u think i can do the flush myself? ill pull the new stat and make sure it opens. but if i can id like to flush it myself..........
Old Feb 9, 2010 | 07:49 AM
You can flush your your own system,check your owners manual for capacity and do a 50 50 mix,then bleed the air from the system,not sure where the bleed screw is on your model but the manual should have the placement.
hondata86
Sep 11, 2013 05:09 AM
puregunzz
Aug 8, 2010 08:55 AM
nkotb
May 23, 2008 08:38 AM
biddums42
Jul 11, 2007 02:16 PM
loganschmidlkofer
Jun 1, 2007 08:02 PM
