94 Accord Missing
Old Feb 27, 2013 | 10:23 AM
trailshredder's Avatar
Default 94 Accord Missing
94 accord has an an occasional miss/stumble at idle and gets worse when revved up. I just replaced spark plug tube seals and had the valve assembly off to do so. I re-adjusted the valves, new NGK's, new wires. Thoughts?
Old Feb 27, 2013 | 11:20 AM
distributor cap hairline crack, rotor gap to wide, coil failing,
Old Feb 27, 2013 | 03:54 PM
lowlife9's Avatar
could be clogged injectors.
Old Feb 27, 2013 | 05:52 PM
Ordered cap and rotor, will give that a try first then test coil if it still misses. What does the group recommend for cleaning injectors, remove and flush or any luck with additives, like seafoam?
Old Mar 1, 2013 | 11:28 AM
lowlife9's Avatar
you could try seafoam first and see if it helps at all then go from there.
Old Mar 1, 2013 | 01:59 PM
I second Seafoam first.
curvenut
Jul 24, 2013 09:12 PM
peruvious
Feb 23, 2011 10:34 PM
rollingthunder6
Jul 30, 2009 09:29 PM
Philiponya
May 24, 2009 07:53 PM
nastyneon
Feb 19, 2009 10:02 PM
