95' Honda Accord 2.7 a/c not working
Old Mar 24, 2009 | 11:39 PM
blitzinator's Avatar
Default 95' Honda Accord 2.7 a/c not working
i have recharged the coolant but it just doesn't seem to be using any of it. it doesn't blow any cold air with a/c on it just always blows outside or recycled air.
Old Mar 25, 2009 | 02:16 AM
s4854's Avatar
Default a/c not working
it seem like a/c system have some leakage in somewhere,
Old Mar 25, 2009 | 12:15 PM
bdmlilburn's Avatar
i would check the vss(vehicle speed sensor) if it isn't working to tell your ac that your car is moving then the ac system will not know that it needs to turn on and will not work.
the vss is located on the transmission
Old Mar 27, 2009 | 12:07 PM
one of my friends who has a father in law thats a mechanic and he has some experience himself had me pop my hood, rev the tachometer to 3 then he said that either the compressor or the condensor (can't remember which) should kick in at those rpm's but it didn't could that have to do with the Speed Sensor also?
Old Mar 27, 2009 | 03:25 PM
sorry don't know about the vss tied in with the a/c. The compressor does not latch on due to freon pressure switch does not work, or there is low freon, or the electrical magnetic latch on the compressor pully is not engaging. If you get a pressure guage kit for the a/c unit, and hook it up to the low side of the guage, you should have approx 20-25 est lbs on the guage. If low service needed but find the leak first.
rimmy
Apr 21, 2011 07:50 PM
e46323i
Jan 25, 2010 12:53 AM
buttaluv
Oct 26, 2009 07:32 PM
ilsalk
Nov 2, 2008 11:45 PM
dougster01
Mar 8, 2008 04:19 AM
