96 acoord stalled while driving, wont start
Old Apr 18, 2009 | 12:17 PM
juschilin77's Avatar
Default 96 acoord stalled while driving, wont start
My Accord stalled while I was driving 2 days ago while I was working. I finally had time to have it towed last night and it still won't start. I also can't get it out of park with out putting the key into the shifter over ride. Any help would be great. I just replaced the fuel pump 3 months ago.
Old Apr 18, 2009 | 12:45 PM
welcome to the forum. check your coil/ignitor, is your timimg belt good, and check to besure you have fuel pressure at your fuel rail.
Old Apr 19, 2009 | 07:12 PM
Thanks for the welcome.
I changed the coil/ignitor, it didnt work. That was a whole different story. The one they gave me did not fit, the mounting holes wre about 3/8" off. but all the connections hooked up and it was the only one auto zone pulled up. Its the TEC not the hatachi. the timing belt is good because the rotor spins. I sprayed starter fluid down the intake while cranking, and did not even get a sputter. Checked for spark, got nothing. The fuse looked ok but had a little petina (sp) on it. Not sure if that would cause the problem but thats what im going to change out next.
Not sure how to check th fuel pressure, but like I said, no spark.
Theres got to be something Im missing.
Old Apr 22, 2009 | 04:07 AM
no spark is normally coil/ignitor, or main relay.
Old Apr 26, 2009 | 12:49 AM
bototech's Avatar
Default You can fix it by Professional Diagnostic Tools
you can fix it by Professional Diagnostic Tools ,please visite website:http://www.bototech.com
Old Apr 28, 2009 | 03:18 PM
fuji576's Avatar
Coil, relay or fuse. Easy fix.
genaro626
Jul 24, 2009 09:37 PM
sadbuttrue08
May 24, 2009 08:49 PM
Sharjite
May 25, 2008 03:52 PM
nighthawk5556
Apr 27, 2008 01:14 PM
largoent
Apr 11, 2007 11:53 AM
