96' Won't Crank
Old Jan 12, 2012 | 04:31 PM
96AccordFromAL's Avatar
Default 96' Won't Crank
Long story short I had an oil leak. Took it in to get fixed and when I got home some of the leftover oil was on the exhaust. I sprayed degreaser on the motor and under the car and washed it off now the car won't even turn over. I have done this probably four times before, and this is the only time it has happened. I know I didn't get the DC wet. What's the next guilty party? Fuses?
Old Jan 12, 2012 | 04:54 PM
That's a negative on the fuses being bad.
Old Jan 13, 2012 | 08:40 AM
Will the head lights come on? Check your battery terminals make sure they are not corroded and tight.
Old Jan 27, 2012 | 10:54 AM
It's a funny thing, when we send our Honda out for an oil change ,it dosen't matter who does it the spillage happens and the drips last days,so I put and old rubber backed rug down to catch the drips.Can't stand a grease floor.
Old Jan 31, 2012 | 04:11 AM
j4anzo's Avatar
Theres a single prong plug on your starter, try that. Whoever did your oil change might have hit it accidentally. they get unpluged quiete commonly.
Old Jan 31, 2012 | 07:34 AM
Well then it shouldn't have started after the oil change.
Old Jan 31, 2012 | 11:59 AM
She's back up and running guys.....check out my other thread if you guys need vinyl decals.
Chris Skoglun
Jun 27, 2016 06:46 PM
diamonddelts
Nov 1, 2009 11:22 AM
Neyne
Mar 23, 2008 09:20 PM
proff
Nov 2, 2006 09:36 PM
Bruster
Aug 19, 2006 04:26 PM
