AC and heat work on settings 3 and 4, but not on 1 and 2
Old Sep 28, 2009 | 09:37 PM
masduud's Avatar
Default AC and heat work on settings 3 and 4, but not on 1 and 2
I also have a 2002 accord se with a new problem (AC and heat work on settings 3 and 4, but not on 1 and 2). I took it to midas and they checked it an said the blower motor resistor needs to be replaced. They said the part costs $200 and the total would be $300. I did some research online and found that you can fix it yourelf. The blower motor is under the glove compartment on the passenger side, but the pictures were from a 98 accord. Does anyone know if the blower motor is in the same location for the 02 accord? I found a new blower motor resister much cheaper on ebay. I also have a 2002 accord se with same problem (AC and heat on work on settings 3 and 4, but not on 1 and 2). I took it to midas and they checked it an said the blower motor resistor needs to be replaced. They said the part costs $200 and the total would be $300. I did some research online and found that you can fix it yourelf. The blower motor is under the glove compartment on the passenger side, but the pictures were from a 98 accord. Does anyone know if the blower motor is in the same location for the 02 accord? I found a new blower motor resister much cheaper on ebay.
Old Sep 29, 2009 | 05:21 PM
08CRaVer's Avatar
ummm
go to http://hondapartsnow.com
they have the part for cheap but they also have the digrams and the instructions to install it
Old Sep 30, 2009 | 10:27 AM
masduud's Avatar
thank you soooooo much. The part is only $52. Midas was going to charge $200 for the part and $100 for labor. I looked under the glove compartment and its just 2 screws holding the blower motor resistor. So it should be pretty easy. Thanks again!
Old Oct 8, 2009 | 01:57 PM
08CRaVer's Avatar
no problem, hope it all works out for you.
I love this webiste aint it great haha great prices too
glad to be of a assistance
Old Jun 14, 2010 | 01:30 PM
slyko's Avatar
You guys are Fantastic!
This forum is Fantastic!
It's listed under the heater/electrical as the blower motor resister!
It solved the problem?
Old Jun 16, 2010 | 11:59 PM
johnfm3's Avatar
Thanks, I also have a 2002 accord that had the transmission problems @ 60,000 miles, the car now has 155,000 on it now and is still going strong. My 1 and 2 settings also don't work, so thanks for letting me know how to fix mine as well
Old Jun 23, 2010 | 11:37 AM
slyko's Avatar
That was it! The blower motor resistor. It took me all of 20 minutes to replace it!
The Haynes Repair Manual confirmed it too!
Ebay had a used one for $30, online for $78, and the dealer had it in stock for $90.
CRaVer YOU are an ACE!
elmendr
Aug 18, 2014 09:31 AM
Jim Britt
May 7, 2013 05:45 AM
jfshop
Apr 7, 2012 03:10 PM
cord92
Jun 11, 2010 01:31 PM
shad9876
Sep 3, 2008 12:57 PM
