Accord Starting Problems
Old 03-29-2020 | 05:37 PM
Yung1's Avatar
Default Accord Starting Problems
So i just got this 2001 vtec 2.3l honda accord sedan. The thing is, sometimes i would drive for 30 minutes and the car would start just fine if i try to turn it on. But sometimes when i drive for only 2 minutes but also as before even longer than 30 minutes the car wont start. When i turn the key all the way nothing happens, no crank nothing.
It happens most often if i drive under 15 minutes.
A car shop has not been able to identify the problem but they thought it was the battery cables.
Anyone have any experience?
Old 03-29-2020 | 09:34 PM
Welcome to the forum. Check for condition of main relay. Check distributor coil for burn spots. Burn or failing coil will cause eng no start after initial run.
Old 03-30-2020 | 04:04 AM
Yung1's Avatar
Hey! Thanks alot. Ive heard that the main relay could be the problem but i told that to the car mechanics and they said there was no possible way. I will have a look at all these things, thank you!
troy1969
06-12-2013 04:38 AM
Loco Ken
10-28-2011 01:06 PM
starrett59
09-17-2010 01:20 PM
squid1991
02-11-2010 12:52 PM
accorddriver96
07-14-2007 06:52 PM
Quick Reply: Accord Starting Problems
