Accord Starting Problems
Old Mar 29, 2020 | 05:37 PM
Yung1's Avatar
Default Accord Starting Problems
So i just got this 2001 vtec 2.3l honda accord sedan. The thing is, sometimes i would drive for 30 minutes and the car would start just fine if i try to turn it on. But sometimes when i drive for only 2 minutes but also as before even longer than 30 minutes the car wont start. When i turn the key all the way nothing happens, no crank nothing.
It happens most often if i drive under 15 minutes.
A car shop has not been able to identify the problem but they thought it was the battery cables.
Anyone have any experience?
Old Mar 29, 2020 | 09:34 PM
Welcome to the forum. Check for condition of main relay. Check distributor coil for burn spots. Burn or failing coil will cause eng no start after initial run.
Old Mar 30, 2020 | 04:04 AM
Yung1's Avatar
Hey! Thanks alot. Ive heard that the main relay could be the problem but i told that to the car mechanics and they said there was no possible way. I will have a look at all these things, thank you!
troy1969
Jun 12, 2013 04:38 AM
Loco Ken
Oct 28, 2011 01:06 PM
starrett59
Sep 17, 2010 01:20 PM
squid1991
Feb 11, 2010 12:52 PM
accorddriver96
Jul 14, 2007 06:52 PM
