Squeaky Brakes (Accord 2014)
Old Mar 29, 2020 | 04:55 PM
Graeme Morrell's Avatar
Default Squeaky Brakes (Accord 2014)
Just replaced the brake pads and rotors (front) took it for a test drive seems to work however when I come to a complete stop in forward or reverse there is a short squeak from one side of the car.
Not sure what I did wrong as I did the same for both (apart from had to replace guide pins on side that is not squeaking due to rounded bolts)
Any ideas of what I can try or will this go away?
Old Mar 29, 2020 | 09:30 PM
Welcome to the forum. When the brakes are cold. Shoot them down with water. Then take it for a test drive. If still squeak. Check both sides for proper installation of parts.
Old Mar 30, 2020 | 07:27 AM
Brake squeaks can also come from parts rubbing against each other
Some use brake grease on the back of the pads and/or on the ears of the pads
This reduces the friction between the pads and brake bracket
And usually quiets down the squeak
debodun
Oct 21, 2019 09:51 PM
Mark Johnson
Apr 24, 2019 06:25 PM
sidpost
Nov 28, 2018 07:51 PM
elo-civic
Nov 11, 2010 02:44 AM
preludeSi
Oct 22, 2010 03:14 AM
