Sponsored by:
Sponsored by:
cabin filter
Old 10-01-2010, 11:24 AM
Default cabin filter
Hey acmech,you have any idea where the cabin filter is on a 2000 accord?The manual says let Honda replace it,I don't see where it should be that hard to do If I can find it.
Old 10-01-2010, 10:16 PM
xmechanic's Avatar
It's located behind the glove box. I would buy a chiltons manual for directions (lengthy directions).
Old 10-02-2010, 03:03 AM
agreed with xmechanic, empty glove box, with the box open, find a way to pull or push the sides inward ( upper fwd soft part of glove box) it will hang upside down and let you see the cabin filter container. some have a slide some have a clip cover to open. pull out filter and replace same. i got my filter from wallmart, napa, autozone, wix, even found some good ones in the salvage yard.... just lucky.
Old 10-03-2010, 09:35 AM
Thanks so much guys,will try that this weekend,regards,Bobby
Old 10-04-2010, 08:56 AM
Aloha Doug,I got the filter out with no problems,found a new one at walmart with your suggestion,thanks again buddy.
Old 09-20-2013, 05:18 AM
michael_cip's Avatar
I have the same problem with this filter... is not so easy to replace. I find here how to do this..i print this page and like this is more easy..
http://filterlocation.com/honda-acco...lter-location/
Thanks!
Old 03-16-2014, 09:00 PM
nycredneck's Avatar
When I changed mine I put a dryer sheet in there as well, works as a prefilter and makes the car smell nice.
Old 03-21-2014, 01:38 PM
HondaTheNextOne's Avatar
I like this idea. I am due to update my filter so I will try this trick as well
Marc
05-21-2012 04:18 PM
stook00
07-08-2011 01:39 PM
jstagn
11-05-2010 02:15 AM
joed2222
06-12-2007 06:14 PM
Quick Reply: cabin filter
