Check Engine
Old Jun 8, 2007 | 10:25 PM
lupo7791's Avatar
Default Check Engine
hi everyone newbie here, i got 1998 accord ex with a check engine light on, went to autozone and they pulled 2 codes which were the same"P1457 EVAP LEAK - control canister system" has anybody experinced this what i'm i looking at something very expensive. any in put greatly appreciated. by the way the car has appro. 124,000 miles
thank you
Old Jun 13, 2007 | 06:37 PM
Default RE: Check Engine
Check your fuel system, fuel tank to injectors for loose clamps cracked hoses, got to check under the car. Start from your gas cap seal.
Aloha and welcome to the forum, enjoy your stay and hope we can all help you out
Old Apr 23, 2010 | 08:15 PM
Kyle's Avatar
I have a 98 accord, with check engine light and same errors, I know this post was a while ago, but if anybody has any answer to these problems, that would be sweet.
Old Apr 26, 2010 | 02:21 PM
Make sure your gas cap is on tight.
Old Apr 30, 2010 | 12:24 AM
jaydawg30's Avatar
Member
check your wiring to make sure nothing is shorted. Could be the 2 way valve or purge solenoid or maybe even the ECU. With the car not under warranty the Ecu can be upwards to 600 dollars. Basically make sure all plumbing is good and all electrical and mechanical components work. Gonna need a DMM(Digital Multimeter) to test the wirings. Look for bad insulation. Tip of the Day: (this may not pertain to you but still a wonderful tip) Never Top Off Your Gas Tank! Topping of your gas tank can destroy your Charcoal Canister which takes harmful gases and makes it less harmful. Anyways, most gas tanks are built to be filled 90% full to contain the gases and topping off will force liquid gasoline into the charcoal canisters and not air. Which is my #1 reason why charcoal canisters fail prematurely. Very, very common to have them last the life of the vehicle. Happy Getting down and dirty. recommend Alldata to help troubleshoot and fix the problem. shhh my little secret.
Old Apr 30, 2010 | 10:40 AM
Kyle's Avatar
Thanks,
I have started the process going through looking for a short somewhere nothing yet, but I'm continue my pursuits and find this problem
samuel_gatech
Nov 4, 2009 04:46 AM
papic03
Mar 6, 2007 09:17 PM
silverbullet
Feb 19, 2007 08:26 PM
cpatd
Nov 13, 2006 02:03 PM
whermanov
Sep 23, 2006 04:16 PM
