Check Engine Light went on
Old Sep 27, 2009 | 05:49 PM
misterix's Avatar
Default Check Engine Light went on
My check engine light went on my 2000 Honda Accord 4 cyl EX ULEV. I then checked the Manual. It said to make sure the gas cap is tight and drive it for 3 trips. Which I did. Please note I flushed my transmission fluid and had my CPU replaced too b/c of a non starting car earlier this year. Autozone ran a check with their machine and the print out came out with one of these problems, please tell me what I should do:
(Please note because it is not an official Honda machine it could be listed under the wrong manufacturer:
Honda:
Open or shut circuit condition
Poor electrical connection
failed TCC system
Automatic transmission fault
Poor connection at transmission
Internal transmission problem
Infiniti:
Bloced passage in transmission
Faulty TCM
Kia:
Failed damper clutch solenoid
Transaxle fault
Chrysler:
Low fluid level
Poor fluid quality
Defective torque converter cluter
Internal transmission failure
transaxle control system fault
failure of transaxle control modyle
Mazda:
Open or short circuit condition
failed TCC solenoid valve
Acura:
Low transmission fluid level
failed TCC solenoid
Nissan:
check for poor connection
failed solenoid
TCM fault
Sabaru:
TPS misadjusted or faulty
MIL light up request
BMW:
Torque converter clutch circuit open
Mitsubishi:
Failed TCC
Transmission control system - mil request
Volkswagon:
Failed torque converter clutch solenoid
Transmission control system fault
Isuzu:
No communication with TCM
failed TCM
General Motors:
TCM requested mil illumination
The TCM has detected an emission related fault
Eagle:
Transaxle control system fault
ECM received a signal that the transaxle control module has a fault
shorted or opend circuit within transaxle
failure of transaxle control module
Old Oct 7, 2009 | 07:30 AM
00 accord had trans recall due to many failures. reset eng ck light and see if it returns, if so have autozone recheck for cause.
fyah17
Dec 22, 2012 03:03 PM
gobabygo95
Apr 12, 2010 09:35 PM
Wai
Jul 1, 2009 03:16 AM
mthafukngreen
Sep 30, 2008 06:34 PM
thesoulcrusher
Jan 1, 2007 11:04 PM
