Front end clank
Old Sep 6, 2008 | 08:06 AM
ODPPOLL's Avatar
Default Front end clank
Hello Honda Folks,
I have a 1999 Honda Accord EX 4 cylinder 2 door with 135,000 miles. When I go over a bump it makes a sharp clanking sound near the driver side front tire. I jacked it up grabbed the wheel and everything is tight. When I drive it (Over 80+) there is no vibration whatsoever. This is my first front wheel drive car so I’m very unfamiliar with the front end. Any ideas?
Thanks
Old Sep 6, 2008 | 05:51 PM
atl's Avatar
atl
Default RE: Front end clank
ODPPOLL, Sounds like we both have a similar problem. If I figure this out I will pass the solution along to you.
atl
Old Sep 13, 2008 | 04:05 PM
pnomaster's Avatar
hey guys, funny i have that problem on my 92, i think it has something to do with the brake pads not sitting properly or basically just not being original honda parts. Does it not do the clanking noise when u brake when going over the bump?
Old Sep 14, 2008 | 08:04 AM
ODPPOLL's Avatar
No it clanks onlyover goodbump. When brakes are applied it's ok.
Old Sep 17, 2008 | 09:07 AM
welcome new members to the forum. check your stabilizer bar bushings, check lower control arm bushings for excessive ware or missing. Check your shock towers to besure they are secure and not floating or loose.
Old Oct 11, 2008 | 11:46 PM
SLEEPER's Avatar
check upper and lower controls arms and strut mounts
sparky-r22
Oct 3, 2009 03:55 AM
wantv8civic
Sep 12, 2009 09:07 PM
NMercier84
Aug 1, 2007 03:11 PM
NMercier84
Jun 1, 2007 06:51 PM
zipzero666
Aug 29, 2006 01:27 AM
