Help with Rack n Pinion part buying
Old May 9, 2022 | 07:29 PM
  #21
C 10 man's Avatar
Banned
Who do you think will find their way to this? They will see your ignorance long before this post.
I do think others are watching this thread and most are getting a REAL KICK out of it, so how deep do you want to bury your self, so far I see you at at least 20 feet at this moment.
I see you don't want to play my Quiz game on the above 8 post you responded to they showed your the TROLL and that probably hurt your feelings.which you really don't have much of in the first place anyway
If someone needs an answer to there question/s about this or that one needs to ask the question for a reasonably answer. For your info I did get Educated from High School and also did go to College for quite a while just not in the area you think.
WOW you just called every one that comes to this forum asking for help or asking questions being a Ignorant person. WOW your not making any friends with that statement here but we all know your not really here to make friends just here to PUFF YOUR CHEST OUT.
Old May 9, 2022 | 08:24 PM
  #22
Who are you talking to? Do you actually believe I am reading all that drivel you posted? Neither I nor any other sane person is reading this. I only respond. You are goofier than I thought.
Old May 11, 2022 | 12:27 AM
  #23
Do you want to take my test? You talked about the windows being power side controlled.
No, I did not say that. I said according to the schematic, ....
Both sides of the motor are connected to ground thru the switch
When activated, the switch will disconnect one of the ground side and connect the positive to it.
They are NOT. Do you know how a pulse generator and a discriminator circuit work together? They use the + symbol to denote the high side of the pulse NOT battery +.. Similar to can bus that has a high and low side.
There is no pulse generator or a discriminator circuit in the schematic.
The line comes off the battery thru a fuse and to the switch and then to the motor.
The ground line also goes thru the switch and to the motor.
Nothing else in between.
Has NOTHING to so with the battery
You say I can't learn. In a sense that is true. In order to learn you need a teacher. You are NO teacher.
Let's stop this and put it to the test.
Do you want to take my test and show everyone who reads this how smart you THINK you are?
Either yes to the test or keep your non-sense to yourselves.
You are still being that block of wood.
You did not even look at the schematic
​​​​​​​So, only crap is coming out of your mouth.
Old May 11, 2022 | 12:39 AM
  #24
Originally Posted by C 10 man
19 posts had gone on with ONLY TWO #1&2 having any answers to my original question and #2 post is wrong NAPA doesn't sell new rack n pinions only rebuilt ones.
This is true.
You can almost see that he is a retired fart who has some experience in a repair shop
But not actually doing any work himself. No repairs.
He knows a little but not enough to be flexible to understand anyone else
It is his way or he will bug the heck out of you.
Remember, he is retired. So, he has lots of time to keep posting his "puff out the chest" posts.
It seems he can get away with it here.
But, on other forums with more active members and mods, they will drive him to shut up or get out.
And, while I did not answer your question, I did try to stay out of the way.
Well, you know what happened.
Old May 11, 2022 | 07:53 AM
  #25
Originally Posted by avisitor
This is true.
You think you know me? You guys are sick pups.
Old May 11, 2022 | 12:45 PM
  #26
We know what you present here thru your posts.
And that is sick.
Old May 11, 2022 | 01:38 PM
  #27
And that is sick.
Your problem is you can't point to one thing I suggested that was wrong. On the other hand you suggest things that you do not understand. I try and help you with your error and all I get is your stubborn idiotic responses. Will you debate electronic theory with me?
Old May 12, 2022 | 01:18 AM
  #28
Are you really that stupid?
We already disagree about what is a power supply versus what is a power supply circuit (which is basically a filtering circuit).
Now you want to debate electronic theory?
Just open another can of worms and get yourself a mouth full.
Old May 12, 2022 | 08:40 AM
  #29
Let's debate this....
Tell me how a power supply is basically a filtering circuit.
Get your google going and see if you can find an answer for this.
How about this....
Does a module that works on 12 VDC need filtering like a module that works on 120AC?
Let's talk and try not to resort to name calling.
Old May 13, 2022 | 01:36 AM
  #30
How about this....
I started to answer you. But, then I realize you just would not understand it.
Next would be that you would just assume it was Google searched.
Personally, it does not matter to me how anyone learns something as long as they are learning.
So what would be the sense in talking with you?
If you do not like the word filtering circuit then try regulating circuit. It regulates the voltage coming in.
Maybe that will relieve that warped mind of yours.
Just dry up and go away.
