Honda Window question
1998 Honda Accord
Two Door drivers window moves up and down easily.
Problem window will not go all the way up.
It goes up 95 % and then just hovers there like something is spinning and it cannot go to the top. Took the door panel off everything seems in order, window is tight in the channels, where the glass is attached to the runners is solid, nothing loose within the door.
Anyone have a solution.
Thank you in advance, I'm new to this forum.
Brian
Brian
Welcome to the forum sir,After doing some research on this problem it seems the Pivot point on the primary arm is prone to failure,it allows some slack in the regulator ,which accounts for it rolling almost all the way up .Here is a good deal on a new one.http://www.autopartswarehouse.com/re...placement.html
silverbullet
Jun 21, 2007 12:31 AM
