Lock is stuck.
Bad day. I noticed that my key was getting harder to push into the driver side door, so I got some lubrcating spray oil and the little extender tube got stuck inside the keyhole. I couldn't pull it out by hand so I got the plyers and it broke off in there. Damn it!!! Any advise? 2004 accord.
You can try going to the dealer to get a match lock cylinder for you bad doorlock.
You can replace the cylinder without replacing the doorlock assembly.
I believe you will get a new key with the new lock cylinder as well.
Try dealer first, if not available then you can carry (2) keys or get all matching locksets from a junker.
Good Luck!
Dongss
Good Luck!
Dongss
pandong
Sep 15, 2007 03:27 PM
