Lock is stuck.
Old Jun 20, 2007 | 12:58 PM
73Charger's Avatar
Default Lock is stuck.
Bad day. I noticed that my key was getting harder to push into the driver side door, so I got some lubrcating spray oil and the little extender tube got stuck inside the keyhole. I couldn't pull it out by hand so I got the plyers and it broke off in there. Damn it!!! Any advise? 2004 accord.
Old Jun 20, 2007 | 01:09 PM
73Charger's Avatar
Default RE: Lock is stuck.
Well I was able to get the plastic tube out but the lock is still stuck.
Old Jun 21, 2007 | 05:56 AM
suggest taking the lock out and taking it to a lock smith to clean out or fix, or you may have to get a new lock with a new key. or go to a salvage yard and get all door locks w/key to replace.
Old Jul 18, 2007 | 09:55 PM
Dongss's Avatar
You can try going to the dealer to get a match lock cylinder for you bad doorlock.
You can replace the cylinder without replacing the doorlock assembly.
I believe you will get a new key with the new lock cylinder as well.
Try dealer first, if not available then you can carry (2) keys or get all matching locksets from a junker.
Good Luck!
Dongss
pandong
Dec 9, 2007 05:30 PM
pandong
Sep 15, 2007 03:27 PM
theokengineer
Nov 25, 2006 10:46 PM
wb925
Oct 30, 2006 04:02 AM
Hannu
Sep 28, 2006 02:43 PM
