my 94 accord sometime wont start
when i start my car for the 1st time its good but the min i trun it off and want to trun it back on it will crank but not start ! So ones its on i dont want to turn it off plz let me
Welcome to the forum,Wish I could help,but the only thing that comes to mind is a bad starter,sometimes a bad starter will give problems when heated up,when the car cools down does it start every time? if so I would say try another starter or try putting a heat shield on the starter,the exhaust may have something to do with it ,do you have a header on it?
b4 you do any of that make sure your battery is good... If you have a digital multimeter. set it on dc volts and measure the amount of volts the battery has. anything under 12.4 volts means its time to drop a new battery under that hood of yours.
thank you everyone for welcomeing me to the forum . i have a new battery in it and i dont have header it only happens when the car is hot but not all the time sometimes it will start wit no problem but other times i have to put starting flud in the air intake then it will start i can go anywher with my car like this !!!!!! 94 accord
So the car hooked on the juice means.... if you know for sure its not the starter it will play around when going out they get kinda moody, never hurts to take it off bring to parts house and have check very painless removal. means timing could be off plug gap wrong run hotter coils or plugs could fix. possible low compression, idle set too low..... but would first try the free take the starter off and have it checked for free at local parts store. or simply on hondas some time a sensor pig tail has a short in it and jacks with it. if any of this helps there it is.but if not let me know i have Honda Service Manuals (not chilton or the others actual by Honda ) on hand please let me know.One more thing starting fluid is good and all but better using stuff such as wd 40 or some thing similar using starting fluid too much will damage your engine.
Hope This helps.
Hope This helps.
