accord lxi wont start help
Old May 1, 2009 | 11:23 PM
petey882's Avatar
Default accord lxi wont start help
i bought a motor from the junkyard with supposedly 80000 miles on it so i swapped the motors out and tried cranking the new one and wont crank did compression test and got the following readings 210, 150, 210, 120... can anyone tell me what it is supposed to be and wouldnt it at least try to start or sputter or something even with that much or would it not start at alll please help if its cheap and simple id rather not pull the motor back out
Old May 4, 2009 | 02:51 PM
I don't know a lot about Hondas but if you don't get at least a sputter like it's tring to run then my guess is an electrical problem ,does it turn over when the starter cycles? Do the head lights come on ?
Old May 6, 2009 | 06:08 AM
do you have spark, fuel.?? compression should all be close to the same, but ok for used and after you run it a bit, compression may come back up.
Tennessee1
Jun 28, 2011 07:17 PM
gac98521
Oct 29, 2009 01:07 AM
petey882
May 10, 2009 08:17 AM
pshsguy18
Apr 30, 2009 03:11 AM
FcPrefix
Jul 21, 2008 05:08 PM
