poor gas mileage
Old Mar 3, 2011 | 09:59 PM
proud-owner-of-zippy's Avatar
Default poor gas mileage
Hello guys
I got my tie rods and boots replaced, thanks for the advise. Now, my next problem. My car gets poor gas mileage, about 22 mpg combined driving. (1984 Honda accord hatchback) I feel it should get better than this. The car is running well, and I have recently tuned the car up, plugs, wires, filters, etc. The car is smooth on acceleration, and idle is pretty good. The fuel burning does not "smell" too rich. Does anyone have suggestion as to what could be the problem? Thanks
Old Mar 4, 2011 | 05:53 AM
did you get your wheel alighnment after the tie rod boot replaced or when was the last alighnment? tire pressure at 35psi, and is the carb mixture adjusted to 14-1 air to fuel.
Old Mar 4, 2011 | 01:55 PM
Didn't think of the alignment,good catch.
Old Mar 4, 2011 | 09:17 PM
jaydawg30's Avatar
Member
using additives is a good first step to clean your system out
Old Mar 5, 2011 | 07:25 AM
Thanks for your answer guys. I've used fuel additives to clean system, aligned the car, but I don't know about the fuel ratio one of you mentioned. I'm afraid I'm not that advanced. How could I check this?
Old Mar 7, 2011 | 08:00 AM
Find some numbers on the carb somewhere and contact Honda they will tell you what carbs you have. Once you know exactly which carb you have you can research online for the manuals for properly adjusting and setting idle for this particular model.
I would guess it is running to rich.Good luck,Bobby
danielm05
Jun 28, 2013 12:52 AM
gkinsha
Feb 2, 2007 01:43 AM
Doug
Jan 8, 2007 02:45 PM
civicstein
Jan 5, 2007 01:49 AM
eltee23ld
Dec 4, 2006 05:42 PM
