Simple HP increase
Old Oct 27, 2009 | 04:10 PM
99accordcoupe's Avatar
Default Simple HP increase
Hey guys,
I am looking to get a bit more HP out of my 2.3L Accord. Do you kinow if there is a big difference between cold air intake and ram air? And would a simple set of headers and cat back exhaust get my car moving a bit quicker?
Old Oct 28, 2009 | 04:45 AM
matimar30's Avatar
Member
you may end up with a big project unless there's a kit for the ram air. as for the cold air make sure there is a bypass just in case the primary filter gets wet. it's normally mounted very close to the ground. as for the exhaust system. if you are going to get headers do a little research so you don't get too large/small of a diamiter on your pipings. you might as well replace the hole thing. headers, high flow cat and exhaust.
or just get a full flow cat. and exhaust only. make the piping larger from the cat to the new exhaust and you'll get a bit of improvement. that's what i did on my vw jetta. magnaflo cat with a flowmaster exhaust(i love the sound on the flowmaster compared to magna flow but magnaflo makes a better cat). wrapping the headers will also keep you engine compartment cooler too. a real pain to do but may be worth it.
keep the old ones for smog checks. i don't think they make a better cat than original honda parts.
if you just want a minor improvement than do what i did. kn stock replacment air filter. good after market silicon plugs, ngk iridium plugs and syn oil (syn is normal now with new cars)with kn oil filter.
Old Oct 30, 2009 | 12:26 AM
91haydenSI's Avatar
invest in a good cold air intake redo the spark plugs and wires and get you a nice set of headers,downpipe, and full catback exhaust.. you can even leave the stock muffler so it doesnt sound like a ricer and it will make a world of difference.. i think if i remember right it can make up to an extra 35 hp
HondaJohn
Aug 1, 2012 08:09 PM
kevcal93
Sep 20, 2009 11:04 AM
Gas Saver
Nov 19, 2008 11:44 AM
DMC_S2000
Dec 9, 2007 06:06 PM
