wiring harness question
Old Jul 4, 2013 | 04:25 PM
TimHays's Avatar
Default wiring harness question
I bought a 96 accord, it was run on a flat, wadded up the passenger side wheel well harness around the CV axle. V6 auto, found a used one, from 1995 accord v6 auto. Took it apart, new harness from the 1995 has two plugs, old one appears to have just had one(unless the wires were ripped clear out) I cut open the harness case behind the glove box, and found nothing that appeared to be the broken off. second plug appears to run second fan and ac comp. power. I carefully unwound the wadded up one( its in pieces) and couldn't find a doubled up wire anywhere. Pin locations appear to be the same on the big plug and same amount of wires. 13, harness out of the 1995 has 13 plus the two. the two wires in the extra plug are a red wire with gray dots every inch, and I blue with green stripe ( I think) will recheck if necessary. Harness runs lights, washer, ac, ac radiator fan, and horn. Can I successfully modify this harness? Was there a second plug that was ripped out and I need to look better? I'm stumped. Any help would be greatly appreciated, tim
1970CL175
Sep 7, 2019 08:07 PM
cturl69
Mar 1, 2014 09:54 PM
Hoodie951
Apr 9, 2010 10:14 PM
jrandall12845
May 28, 2009 03:59 PM
jerij
Aug 13, 2007 09:29 PM
