02 civic front brake issue
Old Dec 22, 2019 | 02:29 PM
70383roadrunner's Avatar
Default 02 civic front brake issue
I've had this issue for a couple weeks. The drivers side wheel heats up so you can't touch the wheel lugs. I took it to one guy and he said it was the caliper. He replaced it with a rebuilt one. Issue still persists. Took it to another shop and he said it was the brake hose. He replaced it. Still the left front wheel heats up so you can't touch the lug nuts. Does anyone here know anything about brakes and how to resolve this issue?
Old Dec 22, 2019 | 06:01 PM
Welcome in, this is a long shot but what condition is the wheel bearing ?
Old Dec 22, 2019 | 06:19 PM
No idea. I guess that would be the next thing to replace. Is there any way to check? I know the passenger side lug nuts dont get hot at all. Could it also be Master Cylinder?
Old Dec 22, 2019 | 10:41 PM
If the master cylinder locks up then either both front or all four brakes lock up
So doubtful to be master cylinder being the cause.
With the front of car jacked up on jack stands and parking brakes engaged, (front wheel drive only) spin driver's side wheel
and have someone step on brake then let go
Check to see if the caliper lets go of the wheel by spinning the wheel
If it moves freely then wheel bearing is suspect
If it doesn't want to move then caliper is suspect.
In that case could be caliper, hose, guide pins, bracket ... (holding pads against rotor)
Good luck
Old Dec 23, 2019 | 06:48 AM
With the front of car jacked up on jack stands and parking brakes engaged, (front wheel drive only) spin driver's side wheel and have someone step on brake then let go
Good luck
When the second guy replaced the hose and blead the brakes on the lift he had a helper hold the brake pedal down and release it as he spun the wheel. When he pressed down the wheel didnt turn. When he let off the brake the wheel spun freely.
Old Dec 23, 2019 | 10:11 PM
Did he do that test before he replaced the hose?
That would have told you whether it was or was not the hose at fault.
Also, checking it now, after it shows the same heating up symptom, will give you a clearer picture.
Still some will just throw parts at the car hoping to fix it.
Wish you good luck
Khrystian Melvin
Nov 14, 2019 07:24 PM
jastrong
Aug 28, 2019 01:35 PM
markelmore
Feb 7, 2016 08:29 AM
suzy fisher
Dec 1, 2008 12:45 AM
Dexter1
Jul 19, 2007 07:39 PM
