1993 Honda Civic Starting Problem
Old Jun 21, 2017 | 12:46 PM
dada6281's Avatar
Default 1993 Honda Civic Starting Problem
Hey guys,
I drive a 1993 Honda Civic Coupe EX, it's been having an issue with starting up; whenever I attempt to turn it on during a cold start it starts right up. During the day whenever I'd make stops i would have to pray that it starts. Whenever I turn the key the check engine light comes on and then off and when I ignite it; it starts making a constant clicking noise. I took it to autozone to get it checked out and the battery, starter, alternator, etc is all fine. The guy said that it may be a connection issue so I cleaned all the connections but it still does it. This issue mainly occurs when it's super hot outside, not sure if that plays a roll. Thanks in advance for your help!
Old Jun 22, 2017 | 08:54 AM
welcome to the forum. check the main relay.
Old Jun 23, 2017 | 11:51 AM
HondaPartsConnection's Avatar
Possibly has worn starter contacts in the solenoid. It will cause intermittant starting like you describe. AS long as s ong as your batteruy is good and teh connections are tight and clean, it most likely is a starter failure.
Does the engine turn over when the clicking noise occurs?
Old Jun 25, 2017 | 02:53 PM
dada6281's Avatar
Bought a new one and installed it but it still does the same thing.
Old Jun 26, 2017 | 09:45 PM
It's got to be a starter relay or ignition switch.
Old Jun 27, 2017 | 11:07 AM
Lavus's Avatar
Member
I just asked a friend of mine who works for DSRLeasing but is a great honda fan and he said that it's pretty common problem and it's usually ignition switch. Hope it helps
HondaChyck09
Dec 24, 2009 05:12 PM
rayh2
Aug 12, 2009 12:38 PM
vstoneinc
Mar 28, 2009 12:42 PM
boostedhatch
Mar 9, 2008 11:35 AM
cosmo
Jul 25, 2006 12:25 AM
