1998 civic Timing Belt replacement
Old Apr 22, 2007 | 01:25 AM
mechanic's Avatar
Default 1998 civic Timing Belt replacement
I'm trying to replace my timing belt on my 1998 civic LX, but I haven't had any luck removing the crankshaft bolt. I'm turning counterclockwise to remove it. My 6 inch extension on the socket to my cheater bar snapped. My question is this, 'is the crankshaftbolt suppose to come out when I turn counterclockwise or clockwise?'. Any help will be appreciated. You could email me at prieto_3@msn.com.[&o]
Old Apr 24, 2007 | 03:24 PM
carlosautochamp's Avatar
Default RE: 1998 civic Timing Belt replacement
heres what goin on the thing has that loctite on it. hers what i did i took to my buddies shop and he had to heat it up and impact it off then snug itback down so you can make it whereever you need to get it. instead of a cheater bar which i think is a breaker bar i used the emergency lug tool wich is 19 mm also and its alot thicker but ifu can use an impact use it have fun and while ur down there replace the water pump its a bitch to get it all taken apart so take advantage
ar777
Nov 30, 2013 07:44 PM
jmurphnd
Dec 6, 2010 07:28 PM
zendao
Sep 14, 2009 11:18 AM
akamina 2005
Oct 31, 2008 04:30 AM
