Timing belt replacement? 2004 Civic LX
Old Nov 15, 2013 | 02:55 PM
ar777's Avatar
Default Timing belt replacement? 2004 Civic LX
I have what I can only describe as a "Cement Mixer" sound coming from the "front" (right side as you look at it) of the engine. In the area under the plastic timing belt cover.
The engine seems to run ok, not like it is skipping or anything. Another thing I noticed, my heat doesn't work. Could this be the water pump?
98K miles.
Any guesses appreciated. Probably going to take it to a mechanic, but want to have a decent idea of what is going on prior.
Old Nov 15, 2013 | 03:38 PM
lowlife9's Avatar
could be the water pump but its impossible to diagnose things over the internet but your due for a new timing belt and water pump. if your belt snaps or skips teeth say goodbye to your engine.
Old Nov 23, 2013 | 01:32 PM
ninjabadger's Avatar
I vote its a bearing. Either the water pump or idler/tensioner pully most likely.
Old Nov 30, 2013 | 07:44 PM
Even the balancer is suspect.
jmurphnd
Dec 6, 2010 07:28 PM
zendao
Sep 14, 2009 11:18 AM
akamina 2005
Oct 31, 2008 04:30 AM
mechanic
Apr 24, 2007 03:24 PM
