2000 Civic HX Intake and Exhaust
Old Oct 7, 2013 | 12:38 PM
aerofranck's Avatar
Default 2000 Civic HX Intake and Exhaust
Hi all,
I have a 2000 Civic HX, with a 1.6 L D16Y5 engine.
This is a daily driver for me, and I am debating trying to get a little more power out of it. As it is right now, if there is someone else in the car it can barely get up to speed on freeway on-ramps. My first stop would be Intake and Exhaust, but I don't really know if it is worth it.
Are there other suggestions anyone has that would be more worth my money?
Thank,
aerofranck
Old Oct 7, 2013 | 04:38 PM
lowlife9's Avatar
no an intake and exhaust will gain you nothing noticeable on 1.6 4 cylinder even with a race header your looking at 5-7 hp increase nothing noticeable. these cars are eco boxes bolt on don't do anything. your only real option besides turbo or complete engine swap is to swap in the vtec head from an EX and then ad a stage 1 cam then the intake header exhaust. if your cars automatic then your really not going to make any gains just from an intake and exhaust.
Old Oct 8, 2013 | 10:41 AM
aerofranck's Avatar
I do have a 5-speed, so that is helpful. When you say swap the head you basically mean replace the cam assembly with one from an EX correct. That seems like quite the overhaul. Are they direct replacements?
Also someone suggested I replace the CPU, do think this would be helpful?
Thank you for your help!
-aerofranck
Old Oct 8, 2013 | 05:51 PM
lowlife9's Avatar
the head is the top end valves lifters springs. yes it bolts on but you also need the ex ecu to run it. upgrading the computer on a stock engine is kinda pointless unless you have the stage 2 cam and i don't think you can use the stage 1 or 2 unless you have the ex head. you couldalso upgrade your clutch stage 1 or 2 and also install a short throw shifter.
Old Oct 9, 2013 | 09:12 AM
aerofranck's Avatar
The 2000 HW does have vtec-e, so it already has the 2 stage cams. But the 2nd stage kicks in around 3200rpm instead of the normal like 6000rpm.
I was thinking about upgrading the ecu so that I can get rid of the efficiency tune. If the stock cpu is tunable though, then there is no reason for that.
In regards to the clutch, that would just make it a quicker shift no? It would not add any hp.
Thanks,
-aerofranck
Old Oct 10, 2013 | 11:49 AM
lowlife9's Avatar
when i say stage 1 or 2 cam i mean the camshaft
Old Oct 11, 2013 | 11:01 AM
aerofranck's Avatar
I understand that. I am just pointing out that my engine is a vtec-e already, so it has the 2 stage camshaft.
smrtchpstcks
Nov 21, 2011 10:00 AM
PacMan
Nov 4, 2006 12:13 AM
PacMan
Nov 2, 2006 04:16 PM
ss96dcm
Sep 16, 2006 01:24 PM
lumpy
Mar 20, 2006 04:18 AM
