2009 civic sdn stalls
Old Feb 4, 2019 | 04:01 PM
cmcgowan's Avatar
Default 2009 civic sdn stalls
Car fires up easily. Runs two seconds and shuts down. Pressing accelerator pedal does increase rpm briefly. Must turn off the key to restart. It will not start by simply turning the key again. It was running fine when I parked it. Car sat for 3 days in single digit temps. I added two cans of dry gas and a can sea foam with no improvement. The check engine light is not lit.
Old Feb 10, 2019 | 10:59 AM
It sounds like a fuel system issue.
Turning the key to the on position will prime fuel rail for about two seconds.
Engine will start and then die cause the fuel pump isn't running while engine is running.
Would check fuses and relays to the fuel pump
Don't forget to look at pin sockets to see if there is corrosion??
Hope this helps
CanadianAccord1
Jan 11, 2016 09:15 PM
Unccmike49
Sep 18, 2010 09:01 AM
altn
Jun 11, 2010 01:30 PM
mohd3333
Dec 12, 2009 03:15 AM
Mosquito Guy
Jul 22, 2009 10:26 PM
